Coil spacer help!
Old Nov 26, 2009 | 12:39 AM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default Coil spacer help!
hey everyone im looking to get another inch or so in the front with these 2" polyurethane coil spacers. They can go under the coil, above the coil, or weave it in the middle of the coil and once its in wrap it upwards to its all in. I'm just wondering if I were to release the upper A frame from the assembly would that relieve enough stress so I can put the spacer in the middle of the coil? Has anyone had any experience with these, they were from autozone for 9$ a piece. Thanks in advanced all criticism welcome.
Old Nov 26, 2009 | 12:43 AM
NVANZEE's Avatar
blazers dont have coils. They have torsion bars. You can get an inch and a half by cranking the tbars up.
Old Nov 26, 2009 | 12:45 AM
Default .
it does its a 2wd not 4wd
Old Nov 26, 2009 | 12:48 AM
NVANZEE's Avatar
oh sorry I forgot about the 2wd setup. In that case my buddy put some on his trailblazer. We put them on the bottom. I cant really see it making that big of a difference where you out them. They were fairly easy to do though. You will probably have to rent a spring compressor from autozone unless you have one
Old Nov 26, 2009 | 12:53 AM
Default thanks
ok thanks, was it hard getting the compresser onto the coil or was there room? actually what kind of compressor was it? twas it the kind with the two bars that hook onto the coil and you tighten the down with a wrench?
JasonB503
Tires and Wheels
Dec 11, 2013 12:41 PM
blainenbecky
Mar 9, 2013 10:38 PM
Lancealot
Feb 22, 2011 07:34 AM
jimbosv650
Tires and Wheels
Oct 7, 2008 09:16 PM
94Blaze
Engine & Internal
Jan 5, 2005 09:59 PM
