compatible rear ends
Old Jun 21, 2010 | 05:11 PM
Scrappy's Avatar
Scrappy is on a distinguished road
Default compatible rear ends
Good afternoon! I was wondering where I can find out what are the compatible years for our 1991 Blazer (full size-4x4). We had the brakes done last week & our mechanic suggested replacing the rear end soon as there is a lot of play in the gears and when it's put into gear, it makes a kind of 'clunking' sound. :0(
Thanks so much for your help!
Old Jun 21, 2010 | 08:53 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Sounds like a U-joint not the gears in the rear end. You can check this yourself. On a level surface, parking brake on, tranny in neutral, get under the truck and try to move the driveshaft back and forth. If it moves and clunks (may not) look at the U-joints to see the play. If you can notice any, they're on their way out. If you can really see them jump around, they're shot.
Old Jun 21, 2010 | 11:46 PM
old skool luvr's Avatar
you said it Gimpy.
it sure sounds like you need to find a new mechanic Scrappy (if it does turn out to be a u-joint).
keep us updated.
j89lumaye
May 5, 2011 10:12 PM
Jason Rebellion
Jun 29, 2010 01:31 AM
Cyron
May 16, 2009 12:54 PM
Ridinblazer
Nov 8, 2008 04:52 PM
Bad Ramer Jamer
Sep 19, 2008 08:05 AM
