Broken Tie rod end??
Old 10-03-2012, 04:04 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Default Broken Tie rod end??
So getting ready to leave work today and broke the left outer tie rod clean off, well good thing it was in the parking lot, anyway question is since it is lifted an so on if I do not have the offset tie rods should I put them on? and is there someone making a heavy duty set up to bolt in place of factory? would like this issue to not happen again.
Old 10-04-2012, 06:52 PM
Jase1979's Avatar
Well since nobody replied or commented I went ahead and removed the straight tie rods and installed the offset ones tie rod angles are much better and aligned perfectly,
Old 05-16-2018, 05:25 PM
Tyler Laurie's Avatar
Tyler Laurie is on a distinguished road
Thanks. Only post that mentions installing offset tie rods vs straight on an aftermarket lift kit. (Which is what I'm doing lol) several posts mention them being used on Zr2 trims but I wasn't sure if it was more so specific to the zr2 trim as opposed to lift kits in general.
Zombie
06-18-2013 03:06 PM
-Z-
12-27-2011 12:38 PM
Klturi421
08-02-2011 07:21 PM
Havensk
07-25-2010 08:16 PM
steelcityneal
07-22-2010 08:47 AM
Quick Reply: Broken Tie rod end??
