CV axel separated at the boot; is it suppose to?
Old Jul 28, 2020 | 02:11 PM
RedValor's Avatar
RedValor is on a distinguished road
Default CV axel separated at the boot; is it suppose to?
Doing some suspension work on my 4x4 S10 Blazer replacing tie rods and ball joins. I separated the ball joints on my driver side, steering knuckle fell off, and the axel came down with it. It separated at the inner boot. I had already did the passenger before and that axel didn't fall out. Look at the driver side and comparing it to the other, it seems to be missing an aluminum clamp. I checked to see if it got pulled off somehow but I don't see it. I may have been driving ot for miles without the clamp and it just fell off somehow.
My real question: is the axel designed to separate at the boot if it doesn't have that clamp? Making sure I didn't break the axel and need to replace it.
Old Jul 28, 2020 | 02:50 PM
It is not supposed to do that but it is easily repairable with a replacement boot kit. It is worth doing since you know the grease is not contaminated and the joint should be good.
Old Jul 28, 2020 | 03:31 PM
RedValor's Avatar
Ok. So I didn't damage the axel by pulling it off accidentally? I'll look into a boot kit and put a new clamp on.
Old Jul 28, 2020 | 03:56 PM
No damage as long as it didnt hit anything, and I would double check for debree before installing the new boot
Old Jul 28, 2020 | 04:33 PM
I used a boot kit from NAPA. You can also get grease packets from them for the boot. I had my boot slip off while doing some repairs and took the opportunity to clean it up and repack it.
I've attached instructions from my 99 Service manual in case they help. You need the fancy tools. But you will need snap-ring pliers.
Old Aug 4, 2020 | 09:48 AM
Stro53's Avatar
Stro53 is on a distinguished road
Default Axle
No you need to replace the cv axle shaft..I wouldnt.keep driving it too long .I just had mine replaces.alomg with upper/lower ball joints and upper control arms on my 99 Jimmy.But no your.bokt needa.replaced and.more less the cv axle shaft..
Koteli
Aug 4, 2020 09:52 AM
matt9589
Aug 21, 2013 09:55 AM
kiwiblazer
May 26, 2010 06:51 AM
Dpepe79
Aug 18, 2009 07:54 PM
whitehope77
Apr 29, 2009 11:05 AM
