cv axle shaft seals.
I was reading a site about jeep. Said you have to pull differential to replace axle seals.
I do not need to do that do I ??
Anyone have part number for front lip seal on both sides.
I searched Alldtata but cannot find part number.
Just so no confusion I need the seals where the cv axle shaft connects to diff. if there is one or is seal inside diff??
1999 S10 Blazer 4.3L 2 door, auto,LS, Vin W 4x4
i beleive wolfpack just changed his cv shafts and seals a while ago and all he had to do was remove the cv shafts to get at the seal, ive got a 2wd so im not to familiar with the 4wd's, but you shouldnt have to remove the whole diff.
Does anyone have a part number for the front cv axle seals. I am confused over what the name of the seals are, like wheel seal, axle seal, oil seal, inner, outer On the pictures I have seen the seal looks way to big on inside diameter. I need the seals that seal the cv axles at the differential.
Better yet where can I get the right seals online.
1999 S10 Blazer 2 door LS auto 4.3L 4x4
Thanks in advance.
Thanks in advance.
leaky_seals
Nov 25, 2013 08:39 PM
benthm7
Dec 25, 2012 04:25 PM
bertrenolds
Nov 7, 2012 03:05 PM
jmaynard
Jul 12, 2011 01:03 PM
