cv axle shaft seals.
Old May 14, 2009 | 02:32 PM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default cv axle shaft seals.
I was reading a site about jeep. Said you have to pull differential to replace axle seals.
I do not need to do that do I ??
Anyone have part number for front lip seal on both sides.
I searched Alldtata but cannot find part number.
Just so no confusion I need the seals where the cv axle shaft connects to diff. if there is one or is seal inside diff??
1999 S10 Blazer 4.3L 2 door, auto,LS, Vin W 4x4
Old May 14, 2009 | 02:40 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i beleive wolfpack just changed his cv shafts and seals a while ago and all he had to do was remove the cv shafts to get at the seal, ive got a 2wd so im not to familiar with the 4wd's, but you shouldnt have to remove the whole diff.
Old May 14, 2009 | 02:55 PM
All that you have to do is remove the CV shaft and then pop the seal out and carefully install the new seal.
Old May 14, 2009 | 03:10 PM
blkblazer's Avatar
Default cv axle seals
Thanks a lot.
Old May 30, 2009 | 09:04 AM
blkblazer's Avatar
Default front axle seals
Does anyone have a part number for the front cv axle seals. I am confused over what the name of the seals are, like wheel seal, axle seal, oil seal, inner, outer On the pictures I have seen the seal looks way to big on inside diameter. I need the seals that seal the cv axles at the differential.
Better yet where can I get the right seals online.
1999 S10 Blazer 2 door LS auto 4.3L 4x4
Thanks in advance.
Old May 30, 2009 | 09:17 AM
oisinirish's Avatar
I believe they're called "axle shaft" seals.
ACDELCO Part # 291324 {#26047378} For an 8.5" ring gear.
Found it at Rock Auto..
leaky_seals
Nov 25, 2013 08:39 PM
benthm7
Dec 25, 2012 04:25 PM
bertrenolds
Nov 7, 2012 03:05 PM
redneck44244
Feb 25, 2012 12:01 AM
jmaynard
Jul 12, 2011 01:03 PM
