Not Again??? font axle seals
Old Feb 25, 2012 | 12:01 AM
redneck44244's Avatar
redneck44244 is on a distinguished road
Default Not Again??? font axle seals
well let me start off with a little background story, about a year ago my my front drivers side axle seal (cv shaft seal) started leaking so i replaced it with a new one as well as the cv shaft (cause it had grooves worn into it) with a 50$ remaned one. well it worked for about a month and it started leaking again so i replaced the seal again, well 3 seals and 2 cv shafts later all only lasting about a month i just went and got a brand new ac delco cv shaft and seal and that appeared to have fixed it once and for all. then shortly after that my passenger side started leaking and i replaced that with a new seal and remaned cv shaft ( cause it had wear grooves in it also) well that went about 2 months and is now leaking again.so my question is is that should i try another seal or should i just go with a new ac delco seal and shaft or am i just doing something wrong??? Note each time i checked air flow through breather, the axle housing is prefectly round not worped or cracked, and when they would start leaking they would leave small puddles when left sit for a while, sorry for being so long just trying to be detailed .
rexazz2
May 29, 2013 10:19 AM
ChevyBlazerChick
The Chop Shop
19
Mar 27, 2013 09:08 AM
bertrenolds
Nov 7, 2012 03:05 PM
jack215
Mar 9, 2010 06:17 PM
chevy8jr
Mar 12, 2006 11:22 PM
