differential debocale
Old Nov 4, 2010 | 05:27 PM
gumpy69's Avatar
gumpy69 is on a distinguished road
Default differential debocale
thanks for reading this i have just bought a 90 k5 blazer it has 41in swampers on 20in rims i took it for its first road test last night and ended up blowing the carrier through the rear end not sure why . thinking i may need to either change the gear ratio of beef up the carrier unsure what the gear ratio is now belive 323 its a 10 bolt rear end any advice would be cool thanks
Old Nov 4, 2010 | 07:44 PM
69chevelle's Avatar
69chevelle is on a distinguished road
get a 14 bolt.... or at minimum a 12 bolt.
turning 41's you need something beefier then a 10..
I'm turning 44" groundhawgz on 15's with a 14 bolt ff and have NEVER had problems with my rear end....
I'm not sure what options you have with 6 bolt though, mine are 8 lug...
Old Nov 4, 2010 | 07:48 PM
41's are WAY too large for 10-bolt and even 12-bolt axles. You will definitely have to get a Dana-60 front and 14BFF rear if you want to stay with those wheels.
Old Nov 4, 2010 | 07:55 PM
69chevelle's Avatar
right, and swap the front make sure the gearing is matched from front to rear !!
Old Nov 4, 2010 | 08:09 PM
Isn't that what I said?
Old Nov 13, 2010 | 06:14 PM
gumpy69's Avatar
thanks alot for your advice greatly appreciated
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
MusicMaverick
Apr 21, 2007 02:17 PM
dion21379
Mar 24, 2006 03:17 PM
lilred67ddgt
Dec 7, 2005 02:55 PM
