Dont have 4wd
Old May 25, 2008 | 02:05 AM
stevenf's Avatar
stevenf is an unknown quantity at this point
Default Dont have 4wd
I put a 2" body lift with 31's on my 97 Jimmy. Went to test out 4wd and it wont switch into it. Ive had this Jimmy for about 3 weeks and when I first got it, 4wd worked fine.
When I press the 4hi button, it makes a shrill/electric motor noise, but the front axle does not lock. When I press the 4lo and switch into drive, it gives the usual loud clunk, but the front still doesnt spin.
What does this sound like? What should I check first? Please be detailed in how to check what your talking about.
Old May 27, 2008 | 09:30 AM
Swain's Avatar
Swain is an unknown quantity at this point
Default RE: Dont have 4wd
First things first(and cheapest) check all your vacuum lines and replace as needed. There are three lines coming from the a switch on the drivers side of the transfer case, one of them is a vent, one of them runs to underneath your battery where the 4wd actuator is found(another possible culprit) and the other line gets vacuum for the switch. Check them all for cuts, and check the 4wd actuator for cuts as well. I had the same problem a couple weeks ago and it was the line running to the actuator, replaced where the line was cut and it still wasn't working so I checked it out again and it was cut in a second place behind the distributor. I replaced another section and now it works perfectly.
88s10Blazer
Dec 8, 2024 03:31 PM
04SSBlazer
Tires and Wheels
Apr 10, 2013 10:09 AM
whiteman_01
Jul 14, 2010 10:28 AM
9014josh
Feb 10, 2010 04:48 PM
rafa.jrbarajas
Tires and Wheels
Jul 18, 2009 11:07 AM
