Snow coming and i dont have 4wd!
Old Feb 9, 2010 | 09:48 PM
9014josh's Avatar
9014josh is on a distinguished road
Default Snow coming and i dont have 4wd!
hey guys newbie here! i was hoping someone could help me!
i have a 93 S10 Blazer 4WD that about 2 weeks ago the 4wd just stopped working...i click the 4wd button,and the click click noise goes off under the dash as it always does and i hear the clunk in the transfer case.The front driveshaft does engage and spin but the fron differential does not lock.
Ive been researching this and people say its commonly the actuator under the battery tray so i pulled the battery tray up and it appears to be ok but just for kicks i used zip ties on the cable that goes to the diff. and zipped it to hold it out to see if that would work as i was sure it would.
Pulled it outta the garage and stepped on it and it still only spins the rear tires...WTF! im getting frustrated can someone please chime in and help a brotha out!?
Old Feb 9, 2010 | 09:52 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
sounds like your tccm isn't working properly, maybe kyle will chime in, by any chance you in MI (op)
Old Feb 9, 2010 | 09:54 PM
9014josh's Avatar
TCCM? no im actually from Mass
These might help:
4x4 No Worky.... Maybe this will help.... by Hanr3
NV233 transfer case / encoding motor switch by error_401
TCCM stands for Transfer Case Control Module...
Old Feb 9, 2010 | 09:56 PM
NVANZEE's Avatar
Are you sure you pulled the cable far enough to engage the diff. Put it in 4x4 and see if the actuator is compressed. If not then i think you will either need a new cable actuator or the vacuum actuator mounted on the fire wall.
Old Feb 9, 2010 | 09:58 PM
Banned
you could always use the posi lock cable
Old Feb 9, 2010 | 10:03 PM
9014josh's Avatar
yes i pulled it out as far as it would go and clamped it that way and tried it but nothing still...how about that electronic plug on the front differential right where the cable goes into it,what is that? could it have anything to do with it?
Old Feb 10, 2010 | 06:29 AM
It needs to move 1/2" to 3/4" for it to properly engage. You may have to rotate the passenger wheel slightly to align the splines on the collar and axle shaft while you pull on the cable.
That switch is just for the light.
Old Feb 10, 2010 | 12:27 PM
9014josh's Avatar
that may be my problem then...i just got back from the junk yard and picked up 2 actuators..they both work as they should so now i got a spare...hope this works ill let you guys know in about an hour!
any other suggestions please comment!
Old Feb 10, 2010 | 04:48 PM
9014josh's Avatar
FIXED IT! just in time for the snow too.went to the junk yard and pulled out a 4wd actuator thats located under the battery tray for $10 and solved all my problems.My old one did have a very small rip in it enough to not hold the vacuum,thanks for all your help!
justblazin1
Oct 19, 2014 11:12 AM
Blazer51
Nov 2, 2011 12:47 PM
jeffs91S10blazer
Oct 12, 2009 07:49 PM
rafa.jrbarajas
Tires and Wheels
Jul 18, 2009 11:07 AM
stevenf
May 27, 2008 09:30 AM
