Driver Side Body Mount Frame Bolt
Old Mar 26, 2009 | 05:25 PM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
Default Driver Side Body Mount Frame Bolt
I bought new siderails today from westin and i got the passenger side 2 body frame mounts off and mounted the side rail, i got the driver side rear body mount off but my front is frozen and the bolt is stripped, tried everything from impact to regular socket. WHat is my other option?
Old Mar 26, 2009 | 05:27 PM
oisinirish's Avatar
Is the bolt stripped or has the mount nut broken free and turning with the bolt?
Old Mar 26, 2009 | 05:35 PM
no the bolt is stripped
Old Mar 26, 2009 | 05:38 PM
oisinirish's Avatar
Are there threads left between the body mount and the shank on the bolt?
If not you cut the bolt and push it up through.....maybe. That might be a little risky if it doesn't work though. Probably more than a little risky..lol
You may end up cutting a hole in the floor and getting to the bolt from the top side and cutting it there.
Old Mar 26, 2009 | 06:25 PM
yea idk, i mean the bolt is still in the frame, i cudnt even get it to budge so it hasnt moved one bit, its still in there it just wont turn, i ended up stripping the hex on the bolt so now when i put a socket to it it just spins on it. When i meant threads i shouldve said the bolt hex not the threads
Old Mar 26, 2009 | 09:00 PM
You could get a set of bolt extractor sockets that would grab onto the stripped head of the bolt...
Old Mar 26, 2009 | 11:00 PM
Swain's Avatar
Swain is an unknown quantity at this point
Use one of the other bolts you have out to go to a store and get a new one. Then either get a cheap socket that fits the stripped bolt or a nut around the same size and have somebody with a welder weld that on and it should come off fine. Might cost you $5 or a coffee.
Old Mar 27, 2009 | 08:00 PM
oisinirish's Avatar
Yeah. If it's the just the head I'd try welding a nut or some such onto the shank ond go from there. Sometimes a little penetrating oil and some patience or heat will will help. Just be careful with the heat you may melt some manmade materials.
mamawolf70
Apr 10, 2020 10:44 AM
bcny168
Nov 18, 2010 09:15 PM
Ultrashock
Aug 21, 2009 05:04 PM
offskooring
Feb 15, 2009 06:09 PM
95Blazer4x4
Feb 1, 2008 08:19 PM
