Driveshaft Length
Old Aug 11, 2017 | 03:51 AM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Default Driveshaft Length
I have a '95 Jimmy 2 Door 4WD. Rear drive shaft u joint was damaged. Went to pull another one and pulled it from a 2000 Jimmy 4 Door 4WD, but the drive shaft was too long. My transmission is a long tail 4L60E. Not sure what type of tail was on the 2000 Jimmy transmission (more than likely short tail)...Any who, going out there today to find another one, and I want the right fit. Which GM vehicles have the same size driveshaft as my '95 2 door Jimmy?...or is it just as simple as finding a long tail 4L60E and pulling the drive shaft from it?
Old Aug 11, 2017 | 04:58 AM
newguy's Avatar
Think about it for a minute,,, ok 2 or 3 minutes. Why would the 4 door drive shaft be longer than the 2 door drive shaft. Clock is ticking
Old Aug 11, 2017 | 05:15 AM
Because the 4 door body is longer than a 2 door... So I should pull it from a S10 with a long tail 4L60E?
Old Aug 11, 2017 | 05:23 AM
newguy's Avatar
There`s a little thing thats spring loaded, it has a metal strip in it with measurements on it. they come in different lengths. Bring one of these with you
Old Aug 11, 2017 | 05:36 AM
Lmao a tape measure! I don't have one, should I just bring the one I took out and line it up with what I'm pulling?
Old Aug 11, 2017 | 07:04 AM
ChuckNTruck's Avatar
Ok I have to ask, why are you changing the entire driveshaft for a bad u-joint? The u-joint is replaceable, however the factory one are glued in and you need to heat the ears with a torch to burn the glue out and remove them.
Old Aug 11, 2017 | 07:13 AM
I don't own a torch
Old Aug 11, 2017 | 07:27 AM
but you might just get another driveshaft with a worn out joint or a joint that will fail soon. Most shops will not charge much to swap the joint real quick if you bring them the driveshaft. If I were you, i would call around and ask.
A few years back I have to have my jeep driveshafts rebuilt which have complicated double cardan joints in them and the shop charged me $50.
Old Aug 11, 2017 | 09:22 AM
newguy's Avatar
Torch is cheaper than a driveshaft
Old Aug 12, 2017 | 08:26 AM
Turns out since my Jimmy is lifted, a custom driveshaft was installed, 32 1/2 from yoke to u joint. Had the u joint replaced for $35 at drive shaft shop
gitch93
Jan 23, 2013 04:51 PM
kxaz145
Apr 17, 2011 12:56 PM
yarinzim
May 10, 2010 09:20 AM
tony991
Nov 27, 2009 09:06 AM
DLslotster
Tires and Wheels
Nov 23, 2007 04:53 PM
