easy front lift?
Old Apr 3, 2009 | 07:12 PM
stensg's Avatar
stensg is on a distinguished road
Default easy front lift?
what is the best/easy way of raising just the front 3 to 4 inches suspension wise?
Old Apr 3, 2009 | 08:06 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
first of all it would be awsome to know what kind of truck you have and use the search feature this has been discussed countless times
Old Apr 3, 2009 | 09:26 PM
nj4x4blaze's Avatar
5" or 6" Suspension lift kit.
Old Apr 4, 2009 | 10:57 AM
stensg's Avatar
sorry its a 97 s10 blazer
Old Apr 8, 2009 | 06:52 PM
A suspension lift adds stress to all 4 CV joints, all 4 ball joints, both torsion bars and both inner tie rod ends. With the added stress, you'll be replacing those parts more often than necessary. A body lift does not affect suspension parts and kits are available for several different amounts of lift.
Old Apr 8, 2009 | 08:05 PM
90K5's Avatar
90K5 is on a distinguished road
You can get a 2' lift at max from cranking the torsion bars upfront and putting shackles in the rear. Also on top of that you can add a 2" body lift. But other than that you would have to purchase an actual 5-6" kit.
Old Apr 8, 2009 | 10:05 PM
If you increase front chassis ride height, (T bar crank), above factory specs, wheel alignment can be adjusted back within factory specs to keep tire wear at a minumum, but the added stress on the suspension parts mentioned above, will wear out, (or break), sooner. As for lifting the rear with shackles, provided pinion angle is corrected, you should be fine. All things considered, not a wise move. But hey, it's your truck and your money.
fletch125
Lifting Tech
May 15, 2013 08:35 AM
BCKDOOR SL4MMER
Lifting Tech
Apr 11, 2013 01:48 PM
Chevymarine
Lifting Tech
Feb 20, 2011 12:48 PM
awbolton66
Lifting Tech
15
Feb 18, 2011 04:41 PM
kurslt
Oct 14, 2009 06:21 PM
