encoder or what?
Old Apr 11, 2012 | 06:40 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
Default encoder or what?
ok i have a 1997, blazer 4x4, truck at first wouldnt take off in first ooo its a automatica, ok i tried to put it in 4x4 lo and hi it all was clickin the encoder and the tccm but wouldnt go in to either 4x4 setting. i reset the pcm with a scanner i have, i got 2 codes one was a solenoid in the trans , and one from the tccm, but i did get the trans to work fine now, but now the tranfer case wont shift, the tccm clicks but no sound from encoder, i will check the wires at the encoder for voltage tomrrow. 5 volts right? any help i would be thank full.
Old Apr 11, 2012 | 07:22 PM
warthogdriver's Avatar
this may help
https://blazerforum.com/forum/tech-a...ill-help-7180/
its a laundry list of 4x system diagnoses
Old Apr 13, 2012 | 03:50 PM
Default 4x4 fuse
i keep blowin the 4x4 fuse in the panel could it be the encoder motor is bad?
Old Apr 13, 2012 | 04:35 PM
50lb_cat's Avatar
Your on the right track, check your wires for corrosion and volts and post back.
rickr0067
Feb 3, 2010 05:12 AM
88s10Blazer
Jan 31, 2010 12:48 AM
CaboKP
Jan 27, 2007 03:44 PM
OldBlazer
Jan 10, 2007 01:37 AM
dusted800
Nov 18, 2006 10:27 PM
