Flying Grease
Old Dec 3, 2012 | 09:52 AM
MarkK's Avatar
MarkK is on a distinguished road
Default Flying Grease
I recently picked up my first Blazer. 1998 4x4 LT. During the process of replacing the front shocks, I noticed grease splatters around the area of the drivers side front axle. I cleaned all the grease, finished the shocks and took the rig out on a 30 mile drive. No unusual drive noises and the 4x4 engages and dissengages just fine. Upon return, I crawled under the rig and saw a small amount of grease had been slung around the area around the inboard joint closest to the case. The outer joint and boot were clean/dry. You can visually see a ring of grease around that inboard joint. Any ideas what I'm looking at and ease or difficulty of repair?
Old Dec 3, 2012 | 10:32 AM
richphotos's Avatar
I think they have CV boots you can buy and just replace the boot. I am not sure how involved it is to do that though. I would do it soon though, keep losing grease inside there, then you will have problems with your cv axle.
Old Dec 3, 2012 | 11:21 AM
50lb_cat's Avatar
I would stay away from the quick boots. IMO, they aren't worth the time. Just replace the half shaft and be done. The joint may already be damaged.
Old Dec 4, 2012 | 07:03 PM
MarkK's Avatar
Thanks. I had the axle replaced today along with the wheel bearing which was warn. Better to err on the side of caution and fix em both while it was apart.
Old Dec 8, 2012 | 01:44 PM
dustinhxc's Avatar
dustinhxc is on a distinguished road
Grease spat out of both sides of mine after I did the rough country lift kit shocks and control arms in that spot replaced both cv joints and no more grease.
Old Mar 19, 2015 | 12:55 PM
Slickrick4's Avatar
Slickrick4 is on a distinguished road
I just did the RC 2.5" lift and the same thing is happening, My tortion keys are cranked and figured that was the reason it was spitting grease, cause it put the cv shaft on a decent angle. So after you replaced the half shaft, are your keys cranked or no.
96Blazernut
Feb 18, 2010 07:56 PM
Unlimitedsp
Nov 27, 2009 01:15 AM
igot10pinitis
Nov 13, 2007 10:07 AM
07g5gt
Oct 19, 2007 08:17 PM
FirehawkNS
Oct 5, 2007 06:06 PM
