front axle size?
front axle size?
do we have a front axle on the 99 blazers called a 7.2 I.F.S and if we dont what is our front 4x4 assmbley called and wht gears do we have up front?
RE: front axle size?
It is an AAM 725 IFS. It is a 7.25" diameter ring gear.
Your current gears will be the same as the rear end ratio as specified on your RPO sticker in the glove box.
For a complete list of RPO code definitions, CLICK HERE.
Thanks. I want to put new lower gears in my blazer but i was wondering sence i have 4 wheel drive do i also have to put lower matching gears in my front end? Or if i do put them in will it mess up something if i dont have them matching front and back?
If you ever want to use the 4wd again, you have to have matching ratios in both the front and rear diffs.
chowell
03-06-2021 09:47 PM
blajeans
01-09-2013 12:58 PM
jmaynard
07-12-2011 01:03 PM
