Front bumper tow hooks
Old Nov 21, 2016 | 06:21 PM
Toocute350's Avatar
Toocute350 is on a distinguished road
Question Front bumper tow hooks
Hi, I haven`t been on here in awhile.Been busy with life working.I`m in the process of wanting to install two front tow hooks on my 2001 Ls blazer.I`m looking to buy two used tow hooks from a friend of mine.It only has screws on it.I took a look at my front bumper fascia where the fog lights go.Looks like I`ll have to cut the fascia in order to install the hooks.At the same time I took a look at the front frame area where the hooks fasten to.Both frames have a notch on them.From the way the notch looks like..I`m missing some parts.the question I have is..Will I need two pieces of steel also in order to tighten the bolts and nuts to the frame?
Thanks a bunch!
Old Nov 22, 2016 | 12:16 PM
abig84's Avatar
if i remember correctly if they are factory hooks yeah theres a piece of steal that slides into the frame with two threaded holes attached for you to bolt the hooks too.
Old Nov 23, 2016 | 08:05 AM
Toocute350's Avatar
Thanks for the info.But there`s no steel piece like your talking about.You have any clue as to where I can find these steel pieces?Or can I just rig up a coupe of pieces?
Old Nov 23, 2016 | 01:42 PM
abig84's Avatar
it was just a plate that slide into the frame rail behind the bumper. i would guess you can just make em as they were pretty simple. no clue who would still sell them, maybe you can snag them out of a junkyard.
you could just use large washers and nuts inside the frame rail if you dont plan on doing any heavy pulling with them
Old Nov 23, 2016 | 04:13 PM
Jamaroon's Avatar
4wd hooks are threaded so the bolts go directly to the hook. the frame has 2 holes for the bolts to pass through.
I don't know if 2wd ones ever came with hooks or how they were attached.
My 2wd s10 didn't have the holes in the frame for hooks, I drilled the holes myself.
Old Nov 23, 2016 | 06:10 PM
Toocute350's Avatar
I may have to just drill out some holes in order to hook them up.I don`t think there`s any holes on the bottom of the front frame.
Thanks a bunch!
Old Nov 23, 2016 | 06:17 PM
Toocute350's Avatar
I don`t recall seeing any holes on the bottom of the frame.But it looks like I will have to bust out the Makita drill to drill up some holes.If your S10 didn`t have holes I`m sure mine doesn`t either.They do have slots on the inside of the frame facing the engine.Not sure what there for.I`ll probably only use them if need be.Since it`s not a 4x4 I won`t have to use them a whole lot.It`s just that I like the look with front hooks on them.
Thanks for you time!
Old Nov 23, 2016 | 06:23 PM
Toocute350's Avatar
I`m gonna just have to drill up some holes.I`ll just mark the holes from the underside that way I won`t go wrong with lining up the screws.Nothing worse than drilling holes twice in piece of steel.I know for sure it will be a weak point.I`ll just have to get someone with small hands to feed the nuts on the screws.Lol!
Thanks for your time!
raysrh
Dec 14, 2014 08:26 PM
PaulO2288
Aug 31, 2009 10:37 AM
BlaZeR FXB1581
Jul 31, 2006 02:23 PM
vspeers1
Jun 3, 2006 10:51 PM
blazerscooby
Mar 3, 2006 02:01 AM
