Front Drive Shaft Rubbing.
Old Nov 4, 2009 | 04:36 PM
mbrjay's Avatar
mbrjay is on a distinguished road
Default Front Drive Shaft Rubbing.
Ok so I know its down to the lift and tires but what can I do about it?
This pic shows where the rubbing is happening, obviously it only happens when the hubs are locked and engaged in 4WD.
Old Nov 4, 2009 | 10:48 PM
NVANZEE's Avatar
wow thats bad. I would think the only fix would be to have a driveshaft custom made for it, or find a way to lower the transfer case
Old Nov 5, 2009 | 06:54 AM
You could probably clearance the cross member by either heating it in that spot and beating it down or by notching it. Either would be acceptable. You would need to see just how far it goes when the front at full droop (wheels off the ground). If you can move that corner of the cross member by 1/2", you should have enough clearance.
Clocking the transfer case would require a lot more work.
Old Nov 5, 2009 | 07:40 AM
NVANZEE's Avatar
i dont think hes rubbing on the cross member. It looks like the u-joint is binding
Old Nov 5, 2009 | 07:46 AM
Binding will not cause a rub on the outside of the cardan joint like that. It definitely looks like it is hitting on the cross member when the suspension droops down.
Old Nov 6, 2009 | 01:33 AM
NVANZEE's Avatar
yeah i think you right. I looked at it again and it has to be the cross member.
Old Nov 6, 2009 | 06:09 PM
mbrjay's Avatar
Yeah its the crossmember and yeah it only happens when the suspension droops. not all the time. You think i'll be able to notch it a little then?
Old Nov 6, 2009 | 06:38 PM
Most definitely!
Old Nov 8, 2009 | 02:33 AM
mbrjay's Avatar
Haha awesome. Man I've got some stuff to do with this truck for the coming weeks.
Blade_24k
Feb 26, 2014 03:03 PM
lizzj70
Jun 23, 2010 06:57 PM
AL
Sep 27, 2007 08:03 AM
cwiththehad
Sep 5, 2007 01:14 PM
wormburnr
Nov 4, 2006 03:42 PM
