front end
Not for 4wd that I'm aware of. Moog makes great front end parts, but be prepared to spend 400 to 500 dollars to replace your upper and lower ball joints, control arm bushings, complete tie rods, idler arm, pitman arm, and sway bar bushings.
There are kits like this on ebay
here
but who knows how reliable that is.
here
synergyoffroad.com has a front end set if money isn't an issue cause it's 500 bucks. I've got it in my ZR2 and so far not a problem and i've gone through three sets of ball joints and two idler arms. Cheap does nothing but give you headaches with our trucks. Unless you like replacing ball joints every couple months. Another recomendation is solid tie rod sleeves cause the cheapo ones bend easy and solid ones with jam nuts dont seize up on you.
I got my ball joints last winter from rockauto
www.RockAuto.com
Part Number Part TypePrice EACore EA QuantityTotal 2000 CHEVROLET BLAZER 4.3L 262cid V6 FI (W) MOOGK5320Ball Joint$ 56.79$ 0.002$ 113.58 MOOGK5335Ball Joint$ 47.89$ 0.002$ 95.78 ShippingNext Business Day Express$ 26.08 Order Total $ 235.44
www.RockAuto.com
Went in to a local highly rated front end shop for an alignment last year with 65,000 miles on my '99 LS 4WD. Came out with new Moog ball joints, pitman arm and the alignment. Mechanic there said Blazers were tough on ball joints, buy the best - Moog.
It's called a solid front axle swap (SAS).
brino1
Feb 25, 2011 08:05 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
