pissed
Old Apr 25, 2010 | 11:43 PM
blazendizz's Avatar
blazendizz is on a distinguished road
Default pissed
whats up well i been busy with my blazer put new amp and sub in new brakes but...... my passenger sider hub broke both rear wheel cylinders are bad n i need a gasket n lube on my rear end gonna cost bout 150 in parts but idont like messing with brakes so igot abuddy gna do the work i we gta change the shoes on theback cuz there covered in grease idk how much i gta pay the guy to do it
Old Apr 26, 2010 | 02:17 PM
BDS_237's Avatar
BDS_237 is on a distinguished road
Goodnight - I need to start texting more so I can decipher this new language.
Old Apr 26, 2010 | 03:31 PM
Benedict1337's Avatar
putting wheel bearings on isn't very hard took me 2 hours to do both of the front. I wouldn't pay him more than $50
Old Apr 26, 2010 | 06:09 PM
ohsofly's Avatar
I would change your wheel cylinders and rear brake shoes, flush the brake fluid and bleed, and change the seal(s) on the rear diff and refill it for about a hundred bucks... Maybe 4 hours of work. Parts should be about 150-200 or a little more depending on what brand of parts you choose. Shoes and spring kit, seals (axle, input), fluids (2L 80/90, 1L Dot3), silicone and wheel cyls, oh, and a can or two of brake cleaner.
You could do some reading in here and see how to do all that yourself too and save the hundred bucks, a brake job and diff service isnt a tough task, just take one side at a time apart so you can always walk around and see what it should look like when done.
Old Apr 28, 2010 | 12:00 AM
blazendizz's Avatar
well my water pump busted and my belt got tangled in the fan over heated and died rip 91 blazer im on my ps3 typing by the way
Old Apr 28, 2010 | 09:12 PM
TreasonAgainstCaesar's Avatar
TreasonAgainstCaesar is on a distinguished road
Maybe I'm the only one, but your posts are hard to read. Try throwing in some punctuation at least.
Just because it overheated doesn't mean it's dead. Try changing the coolant and oil and fire it up. You have an iron block and heads, they can take a little abuse.
Old Apr 29, 2010 | 10:16 AM
MuddBunny84's Avatar
Banned
i understood it he just abbreviated gotta, gonna, and i dont know....
gta gna idk lol
just gotta GTA slow down and let youre brain figure out the missing letters lol
Old May 4, 2010 | 08:33 AM
blazendizz's Avatar
i know how to spell people i was typing on my ps3 its a pain in the ***.
any way i fixed my truck. I put a new water pump, and serpentine belt on. turns out i did not blow a head gasket nor did i mess up the motor. i still have to fix my pull when i brake other than that she is good to go.
Old May 5, 2010 | 04:13 AM
I believe that you that you know how to spell. I was just saying that because of the lake of punctuation and typos it was difficult to understand your post.
Glad to hear you got the problems worked out. If you over heated it for any significant period of time, you should probably still change your oil and coolant.
pettyfog
Feb 8, 2012 07:01 PM
924dr4wdw/horns
Sep 24, 2010 08:49 PM
88blackzcand95blazer
18
Feb 7, 2009 09:49 AM
igot10pinitis
Jan 20, 2008 12:05 PM
