Front end Q's
Old Oct 22, 2007 | 02:14 PM
blazinloud's Avatar
Default RE: Front end Q's
I have those dang skid plates, hard to see anything [:'(]
Old Oct 22, 2007 | 05:55 PM
drperry's Avatar
Look in from the side, or just behind the front skid plate, the diff isn't really covered by the skid plate...
Old Oct 22, 2007 | 09:00 PM
blazinloud's Avatar
ok, so am I looking for like a dip stick? or just a threaded plug?
Old Oct 23, 2007 | 03:08 AM
drperry's Avatar
Threaded plug for both... The drain plug looks pretty much exactly like the oil pan drain plug...
I'll crawl underneath and snag a pic or two for ya...
Edit:
Here's some pics... Not sure if it's different for the aluminum diff, but if you bring a magnet underneath with ya, and it sticks to the housing, you're lucky enough to have the iron diff, lol
edit 2: dunno if it's my computer or not, but the labels I put in only show up when I click the picture, lol, anywho, hope this helps!
[IMG]local://upfiles/5070/A6C62221F94B4EBBA2BFF650441A67D9.jpg[/IMG]
[IMG]local://upfiles/5070/BD39FA42100245D987B31150A57CBD74.jpg[/IMG]
[IMG]local://upfiles/5070/6A240B23A2334133B28B20C7044B581F.jpg[/IMG]
Old Oct 23, 2007 | 07:40 AM
Just be aware that not all 4wd's had a drain plug. There were two versions of the aluminum front diff housing. One with a drain plug, and another without it... Makes for fun fluid changes.
Anyway, if you do not have a drain plug on the driver's side, then you will need to use a suction pump to remove the old oil out through the fill hole. Once you get it close to empty, clean the suction pump and reverse it to push the new oil back into the diff until it's full.
And if it's leaking, just keep an eye on the fluid level at each oil change.
Old Oct 24, 2007 | 08:53 AM
blazinloud's Avatar
sweet, thanks drperry!
Old Oct 24, 2007 | 01:05 PM
drperry's Avatar
No problem!
Let us know what'cha find!
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
88s10Blazer
Jan 29, 2010 06:31 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
