Front end question
Old Mar 27, 2009 | 09:34 AM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Front end question
Took my Blazer in for a front end alignment to the local shop because the tires had severe toe in wear {outside tire wear}. I thought there may be some loose parts that maybe needed replacing but they said no. All they adjusted was the inner and outer tie rods.{I can see the wear, on the bolts and the sleeves where they put a wrench} Question I have is that would this solve my toe in problem or am I getting hosed on this and other adjustments need to be made. Thanks.
Old Mar 27, 2009 | 10:10 AM
rriddle3's Avatar
Misadjusted tie rods can cause toe-in wear. It can also be caused by worn tie-rod ends.
Old Mar 27, 2009 | 11:41 AM
gmbwrenchn's Avatar
Great........thanks for the info.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
jbeezy1983
Jan 2, 2008 05:11 AM
cliff191
Jul 19, 2007 07:48 PM
