Front Wheel bearing hub assembly brand
Old Jul 5, 2018 | 01:24 AM
Cooney's Avatar
Cooney is on a distinguished road
Default Front Wheel bearing hub assembly brand
Need to replace front wheel bearing hub assembly on my 2002 blazer. There are many different brands to choose from out there and the prices vary widely. Anyone recomend a brand, Is it ok to go cheaper on front wheel bearings or do I need to get AC delco?
Old Jul 5, 2018 | 08:55 AM
El_Beautor's Avatar
In my opinion if you want the hubs to last more than a year you should go with Moog or another high-end brand. The general consensus on the forum is that the cheap brand wheel bearings will fail quickly on these trucks. Even so-called mid-level hubs don't last well. I tried a set of the NAPA brand mid-range hubs and they failed in less than a year. I've been driving on a set of Moog hubs now for almost 2 years and they're as tight and smooth as when I installed them.
Old Jul 5, 2018 | 08:59 AM
Rusty Nuts's Avatar
Timken makes excellent quality bearings and seals. The cheap ones tend to fail more in the abs circuit. It hurts to spend that much, but it only hurts once and then no worries. The 36 mm axle nut gets torqued to 103 foot pounds and the 3 mounting bolts get 77 foot pounds..
Old Jul 6, 2018 | 08:27 AM
Cooney's Avatar
thanks,
I went with MOOG, its what they had at my local auto parts store and had the stronger warranty
Frank Bukowski
Mar 23, 2019 05:08 PM
rexazz2
Mar 3, 2013 08:58 AM
stiggybaby
Jun 11, 2012 04:47 PM
not_only
Apr 2, 2011 11:12 PM
Kendo
Mar 12, 2010 11:49 PM
