Front Wheel Hub socket size help needed.
Can anyone verify for me the size socket needed to replace the front hub on my 1998 4x4 Blazer. It is the axle nut and I watched a utube video specifying a 35mm and a link on this forum using a 36mm. I dont have any that size (32mm is the largest I have) so I am just going to purchase the socket and am looking in advance to make sure I buy the right one.
Thanks for any & all help
Been over this numerous times as a search ("axle+nut+socket+size") would indicate.
The correct size is 36mm. While a 35mm socket may fit in some cases, due to manufacturing tolerances, it may not fit all cases since the proper size is 36mm.
Search FTW!
axle nut size...
Read down to a video I posted of the acceptable slop. I have had this socket for years and used it on many s-series on up to full-size trucks. Just used it a few weeks ago to replace the hubs on my '04 Tahoe.
axle nut size...
Why would you need to buy both? I'm not sure how much clearer I can say this. THE CORRECT SIZE IS 36mm!!!
There is ABSOLUTELY no chance of rounding off the nut with a 36mm socket. So why bother with a 35mm just because it sometimes fits snug and sometimes doesn't fit at all?
*EDIT* I just remembered that I had an old axle nut in the garage that I damaged by hitting it with a hammer to get the CV shaft free from the hub. Measured 35.36mm with my digital caliper. I'll be back in a few with the Machinery's Handbook tolerances for this size nut/socket, but I can say for sure that if it were a 35mm nut, it would not be over 35mm flat to flat. That is a certainty.
*EDIT 2* - Machinery's Handbook calls out M24x3 thread having a nut flat-to-flat of max 36mm min 35mm per ANSI/ASME B18.2.4.1M-2002.
