GET OFF THE RAG. simple steering shaft replacement.
Old Jan 11, 2016 | 12:45 AM
99blazer1029's Avatar
99blazer1029 is on a distinguished road
Talking GET OFF THE RAG. simple steering shaft replacement.
So i found a fix for the rag joint in my 1999 4x4. For a while now i had been getting very sloppy steering, and upon inspection i ifound a bad rag joint. Naturally a peice of rubber didnt seem like a good idea for a steering shaft linkage. So i went to the junk yard and pulled a intermediate steering shaft out of a 1996 dodge ram 1500 4x2 (only year model i found to have this shaft). i picked up for $35 went home and got to do a bit of work with a saw (grinder or dremmel tool will work). Cut off the pinched part that holds in the smaller shaft, should end up with a small ring of metal. Then give her a good yank. Ended up a direct bolt in after i got the two pieces apart. Pictures to show process when i figure out howto upload
Attached Thumbnails GET OFF THE RAG. simple steering shaft replacement.-20160110_232559%5B1%5D.jpg   GET OFF THE RAG. simple steering shaft replacement.-20160110_232640%5B1%5D.jpg   GET OFF THE RAG. simple steering shaft replacement.-20160110_232707%5B1%5D.jpg   GET OFF THE RAG. simple steering shaft replacement.-20160110_232715%5B1%5D.jpg   GET OFF THE RAG. simple steering shaft replacement.-20160110_232726%5B1%5D.jpg
Old Jan 11, 2016 | 11:09 AM
Jamaroon's Avatar
good work. xj's have the same type of joint as well. I went the rout of a lot of other people and ordered the flaming river ujoint to do this one mine.
Old Jan 11, 2016 | 07:17 PM
I tried the xj shaft. Guy at the yard wasn't to thrilled when he pulled it and I didn't buy it because it was backwards. That one seemed like it would work for the 1st gen s10 that had the tulip joint at the other end.
adaptechsolution
Apr 7, 2012 12:03 PM
bbt8831
Dec 14, 2009 10:12 PM
livinterror
Dec 28, 2008 09:50 PM
88blackzcand95blazer
Dec 19, 2008 08:13 PM
