grinding noise
Old Apr 15, 2013 | 11:09 AM
tate456's Avatar
tate456 is on a distinguished road
Default grinding noise
Grinding noise on the front left of my 96 blazer 4x4 beleive its a wheel bearing because when I turn left and take the weight off of it it stops but also ubder heavy braking its stops just wondering if I should check anything else before ording my hubs thanks guys
Old Apr 16, 2013 | 10:14 PM
Neb15's Avatar
Neb15 is on a distinguished road
Try jacking up that wheel and spinning the tire. See if it makes that same grinding noise, if it does I'd say your right about the barring. If not saves from buying extra parts.
Old Apr 16, 2013 | 10:22 PM
If it ends up needing a bearing, don't get cheapos. Timken is first choice, (good stuff). Might want to check the wheel alignment too, incorrect camber will wear out the bearings prematurely. Should be zero degrees for best bearing life.
Billy Jackets
Dec 22, 2009 07:32 AM
JZRALNC
Apr 14, 2008 11:16 PM
havrelm1
Feb 22, 2008 09:01 AM
gohan69
Feb 6, 2008 06:48 PM
blazinloud
Feb 3, 2007 09:08 PM
