Grinding noise under heavy acceleration.
OK thought I might ask here been trying to figure out a problem I'm having. If I am driving normal everything operates perfectly but if I try to accelerate hard I get a gear grinding noise from either the trans or the transfer case. It does it whether its in two wheel or four wheel drive so I am pretty sure its not the rear end. again as soon as I let off the gas and not hit it hard it sound normal. Anyone seen this before?
ok I guess no one has ran into this so I will keep this updated I am beginning to think it might be the torque conveter, hook a heavy trailer up and it does it a lot quicker. any clues on how to check it? fluid for trans is clean.
I'd take a good look at the u joints, look for excess grease on the floor pan or rust on the u joints. Next check your fluid levels trans,t-case rear end. Then look for leakage at the rear wheels, could be a bad bearing.These noises can be a pain to diagnose, I recently changed the left rear bearing and was convinced the noise was coming from the right front.
Same issue
ckroll98
08-29-2013 09:51 AM
deez283
02-27-2012 08:36 AM
madcow
04-20-2010 01:02 AM
GMJimmy
01-27-2010 05:52 AM
shitbox
08-23-2005 11:35 AM
