HELP ASAP.. Torque specs...
Old Jan 15, 2009 | 12:10 PM
livinterror's Avatar
livinterror is an unknown quantity at this point
Default HELP ASAP.. Torque specs...
I need to know what is the torque for upper and lower control arms, upper and lower ball joints and the half shafts on a 1999 Blazer 4wd. Thanks Help me ASAP THANKS!!
Old Jan 15, 2009 | 12:18 PM
Default RE: HELP ASAP.. Torque specs...
I also need to know how tight do I tighten the tie rods? Please help me so I can get this finished!!
THANKS in advance!
Old Jan 15, 2009 | 12:19 PM
Control Arm - Upper = 85ftlbs, Lower = 81ftlbs (do not know why there is a difference)
Ball Joints:
- To control arm (small bolts) - 17ftlbs
- To steering knuckle - Upper = 61ftlbs, Lower = 79ftlbs
Axle Retaining Nut - 103ftlbs
Tie Rod to Steering Knuckle - 39ftlbs
In the future, please try the search function. Also, please edit your post to add more information rather than consecutively posting.
Old Jan 15, 2009 | 12:25 PM
thank you....
Old Mar 21, 2019 | 10:05 AM
8baller's Avatar
8baller is on a distinguished road
Ball Joint To Steering Knuckle79Ft-Lbs948In-Lbs107.11N-mYears:1995-2004Note:Gen II - 2WD - FRONT LOWER Balljoint to Steering KnuckleType:Dim:Length:Head: NutGrade:
Ball Joint To Steering Knuckle61Ft-Lbs732In-Lbs82.7N-mYears:1995-2004Note:Gen II - 2WD - FRONT UPPER Balljoint to Steering KnuckleType:Dim:Length:Head: NutGrade:
Ball Joint To Steering Knuckle79Ft-Lbs948In-Lbs107.11N-mYears:1995-2004Note:Gen II - 4WD - FRONT LOWER BalljointType:Dim:Length:Head: NutGrade:
Ball Joint To Steering Knuckle61Ft-Lbs732In-Lbs82.7N-mYears:1995-2004Note:Gen II - 4WD - FRONT UPPER BalljointType:Dim:Length:Head: NutGrade:
Old Mar 21, 2019 | 10:15 AM
*Thread Closed* - This thread is 10+ years old and you didn't provide any new information. Good Job!
LannyL81
30
Nov 16, 2019 07:34 PM
Captain Kirk
May 27, 2017 11:08 PM
cdtek101
Dec 16, 2016 06:32 PM
litterbox99
Jul 19, 2014 07:31 AM
snowboarder6899
Jan 12, 2008 04:58 PM
