help for a begginer plz
Old Oct 3, 2013 | 08:04 PM
jhaze's Avatar
jhaze is on a distinguished road
Default help for a begginer plz
i have a 94 full size blazer.it has a4inch rcx lift kit on it i recently had to have a repair to fix a leaky drive shaft mechanic has informed me this will be a ongoing problem unlees i undo the lift.i am thinking there has to be some kind of modification i can do to rear end position or drive shaft or maybe both ,.any help would be greatly appreciated thanx.
Old Oct 4, 2013 | 02:43 AM
Diaita's Avatar
It may be the slip yoke bearing is worn, causing excess movement in the slip yoke, and wearing the seal. Another option is a slip yoke eliminator. Check out JB Conversions to see what I mean. I run a 10" lift and still have the factory seal in my blazer.
Old Oct 4, 2013 | 09:51 PM
abig84's Avatar
you have a slip yolk? does yours leak? i got two lifted trucks, k30 with 3-4 inches of lift then the s10 with about 9. both rear output seals leak, have always leaked, been replaced, have changed driveshafts still leak. i just accept the fact that they are just going to leak and have carpet squares on the ground in the garage
Old Oct 7, 2013 | 12:53 PM
Diaita's Avatar
I still have a slip yoke in my Blazer, and it doesn't leak. It's only a NP233, but was running with a 5" lift for 10 years, and a 10" lift for over a year. My '03 GMC had an NP246 transfer case(slip yoke) and a 6" lift with no leaks.
I have the SYE for the Blazer, but the slight vibration I had has disappeared so the SYE sits in the shelf until I get motivated, or have issues with the slip yoke.
I went looking for a link for the bearing in the tail housing, and as nearly as I can tell there either is no bearing, or it's not a replacement item.
blazerguy22
Oct 15, 2009 08:57 PM
familyman
Aug 25, 2007 04:34 PM
kerander
Feb 11, 2007 06:53 PM
twintrades123
Sep 11, 2006 12:26 AM
blazergirl15
Sep 7, 2005 05:18 PM
