help with front end
Old Feb 20, 2010 | 11:50 AM
ryankinder82's Avatar
ryankinder82 is on a distinguished road
Default help with front end
if anyone could tell me what the problem is it would help alot. i have a 1998 4x4. theres a noise coming from the front passenger side. the only time it make a noise is when i completely turn the steering wheel all the way to the right. i can drive it normally and it makes no noise. it sounds like a wheel bearing or ball joint but like i said its only when i totally lock the steering wheel all the way to the right. it does not make the noise when i turn corners or anything or drive it regularly.
Old Feb 20, 2010 | 12:04 PM
awe341's Avatar
awe341 is on a distinguished road
It would help considerably if you could describe the noise.
Old Feb 20, 2010 | 12:07 PM
Sadchevy's Avatar
Sadchevy is on a distinguished road
is the noise a clunk when sitting still (possible ball joint) or is it a rotational noise when moving at full lock (cv axle shaft binding)??
Old Feb 20, 2010 | 12:08 PM
its a scrapping or humming noise. when turning the noise isnt constant, more like a rhythmic sound that increases if i would go faster turning real tight with the steering wheel locked out.
Old Feb 20, 2010 | 12:47 PM
Sadchevy's Avatar
i would say it is a cv joint or wheel bearing. since it only happens at full lock (when most stress is applied) i would check my cv joints first . have you checked it in 4wd ?
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
desertirish
16
Mar 28, 2007 08:01 PM
