Help with noise
My blazer has been makin a funny noise in the rear end. Its been going on ever since i got it. At low speed you can hear a repititious sound like a wawawawawawawa an it only gets faster when speed increases. My dad thinks it might be in the axle or transfer case, but ive talked with my shopteacher an he says its tires. The tires are getting close to when they need to be replaced. Any help?
I had my Auto mech. teacher ride along an listen to the noise hes been in the auto business for 20+ years an he says its tires, so im hoping once i get new tires that the noise will go away, ill just have tread noise.
I'd say universal joint. Just for kicks I would take off the rear diff cover and inspect the gears, also check the backlash of the ring gear in relation to the pinion. A crappy inner bearing may cause this tolerance to be out. Good Luck.
Irish07
Oct 31, 2012 06:04 PM
Chrismacster
Apr 2, 2009 06:57 PM
colinlesser
Jun 9, 2008 04:46 PM
desertirish
16
Mar 28, 2007 08:01 PM
