Help with noise
Old Apr 25, 2008 | 11:27 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
Default Help with noise
My blazer has been makin a funny noise in the rear end. Its been going on ever since i got it. At low speed you can hear a repititious sound like a wawawawawawawa an it only gets faster when speed increases. My dad thinks it might be in the axle or transfer case, but ive talked with my shopteacher an he says its tires. The tires are getting close to when they need to be replaced. Any help?
Old Apr 28, 2008 | 04:08 AM
bs63366's Avatar
bs63366 is an unknown quantity at this point
Default RE: Help with noise
If there is a vibration as well at higher speeds you could have seperated a belt in the tire
Old Apr 28, 2008 | 08:25 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
How do you brakes look you may have warrped or worn out rear rotor if you have rotors or a damaged drum in the case of drums.
Old Apr 28, 2008 | 09:48 PM
I had my Auto mech. teacher ride along an listen to the noise hes been in the auto business for 20+ years an he says its tires, so im hoping once i get new tires that the noise will go away, ill just have tread noise.
Old Apr 28, 2008 | 09:50 PM
blazinrebel's Avatar
blazinrebel is an unknown quantity at this point
is it more of a squeaking noise because if that is the case it would most likely be a u-joint
Old Apr 29, 2008 | 04:10 PM
Not a squeking noise.
Old Apr 29, 2008 | 07:52 PM
Butts's Avatar
Butts is an unknown quantity at this point
I'd say universal joint. Just for kicks I would take off the rear diff cover and inspect the gears, also check the backlash of the ring gear in relation to the pinion. A crappy inner bearing may cause this tolerance to be out. Good Luck.
Irish07
Oct 31, 2012 06:04 PM
Chrismacster
Apr 2, 2009 06:57 PM
colinlesser
Jun 9, 2008 04:46 PM
desertirish
16
Mar 28, 2007 08:01 PM
gabhanjacisa
Engine & Internal
Mar 30, 2005 08:26 PM
