help with trouble shooting 4x4
Old Feb 18, 2012 | 05:15 PM
mrroof1's Avatar
mrroof1 is on a distinguished road
Default help with trouble shooting 4x4
I have a 95 4 door and my 4 wheel quit. At first it was just high range then i did the unhook battery and now i have no 4 wheel drive.
I read all the trouble shooting i can find... when i hit 4 wheel it flashes then goes back to 2 wheel. The tccm is clicking so I assume it is working. I have check connections they all seem to be tight. I have the 16 pin code reader and I grounded pin 13 and it gives me no trouble codes, am i to assume since the switch work and the tccm clicking that the encoder motor is bad? that would be the next step in going into 4 wheel drive so it makes since that it is what is causing the problem.
Also sometimes i ride down the road and the 4 wheel light comes on all by it's self but it is not in 4 wheel and then it goes back to normal showing 2 wheel.
When I drive around and try to engage 4x4 it will get to the point where the 3 wheel lights wont light up anymore or both at one time. I can stop and put it in neutral and it will try to engage again and if i take out the 20 amp accessory fuse then it will go back to normal trying to engage.
Also my clicking is coming from behind the radio area which is where I am told the tccm is but there is another electronic box that I dont know what is behind the right kick panel but i can unplug it with no affect on the 4 wheel drive.
any help is appreciated
Jamie
Old Feb 18, 2012 | 05:49 PM
xgiovannix12's Avatar
this should help you (found using the search feature)
4x4 No Worky.... Maybe this will help....
Matthew L Summey
Feb 11, 2013 10:23 AM
Thompsont
Nov 9, 2011 06:37 PM
mb6790
Sep 26, 2011 06:39 PM
kuraki
Dec 12, 2008 08:09 AM
stevenf
Jun 20, 2008 02:29 PM
