High Speed wheel Wobble
Old Oct 25, 2010 | 01:34 AM
TriBlaKer's Avatar
TriBlaKer is on a distinguished road
Default High Speed wheel Wobble
My truck starts to shake violently anywhere above 70 mph. I 'm looking for some ideas as to what it may be. Oh and its a 98 4dr 4wd blazer if that helps at all.
Old Oct 25, 2010 | 07:09 PM
akmzero's Avatar
akmzero is on a distinguished road
Alignment, wheel balance, I recently had to replace a wheel hub on my blazer.
Old Oct 25, 2010 | 08:49 PM
abig84's Avatar
bent rim or really f'ed up tires too
Old Oct 25, 2010 | 09:14 PM
Rottidog's Avatar
wheel bearing, cv joint or weights, tir rod end, ball joint, probably not weights because you'd notice it at low speeds, like 20 - 40 mph & 70mph? damn man, ease up a bit lol
can you tell if it's front or rear end? might be a counter balance weight that came off the rear drive shaft or if you've been in the mud recently something on the inside of a rim (it would be small to be noticed at higher speeds)
try the NS/EW push/pull when the front end is in the air (lifted by the frame, not suspension), too much movement will tell a lot
Old Oct 30, 2010 | 05:32 PM
kamarasy's Avatar
kamarasy is on a distinguished road
Arrow GO TO: THREAD - vibration 60-70mph
Dear Blazer owners,
The above mentioned thread "vibration 60-70mph" has your answer.
Sorry to say, on Page 2 of the thread, it is reavealed that CHEVY actually knows of the 60-70 mph vibration and is not willing to do anything about it. They seem to have built it into the car.
The original poster of the thread vibration 60-70mph recently posted that he fixed the problem with new REAR AXELS and REAR BEARINGS.
I have suffered with the "bad tires" or unbalanced tires excuse for 4 years.
The above thread is a god send.
Moderator might consider consolidating all high speed vibration threads into one thread with comments from the moderators that this can't be fixed.
I personally find it curious that the rear axels being bent could cause such a common problem. ..
God bless
Last edited by kamarasy; Oct 30, 2010 at 05:34 PM. Reason: Bad Icon the thumbs down is not appropriate.
Pipewrench Dale
Nov 10, 2014 06:16 PM
Tmull6
Jul 2, 2014 09:40 PM
ericthughes
Oct 9, 2011 08:40 PM
68Datsun510
Jun 26, 2009 10:06 PM
JediKnight2
Apr 24, 2008 07:51 PM
