How do you change a wheel hub?
Old Apr 21, 2010 | 11:23 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
FYI. I loosened the axle nut with the tire on the ground. Much easier. Did mine in about 3 hours including the upper and lowe ball joints.
Old Apr 21, 2010 | 08:25 PM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
Hey guys, thank you for all your help I got it changed today, took a while because I needed a cheater bar and I had to go buy an 18mm wrench which I couldn't find anywhere so I ended up buying a $15 wrench set. Just so everyone knows for future reference it is a 36mm center nut and the bolts holding it on are 18mm and you cant get it with a socket.
Old Apr 21, 2010 | 08:27 PM
Drifter666's Avatar
I shoulda thought of that, i ended up putting it in 4wd and parking it then because the bearings were so bad i put the brakes back on and wedged a snow brush to apply the brakes worked great.
jayj99jimmy
Dec 13, 2011 07:48 PM
88s10Blazer
Jun 4, 2010 04:56 PM
grime
May 13, 2010 10:58 PM
johnsonmopar
Mar 10, 2008 06:49 PM
Marcin
Nov 9, 2006 11:31 AM
