Bearing/Wheel Hub Noise?
Old Apr 17, 2010 | 08:41 PM
GMJimmy's Avatar
GMJimmy is on a distinguished road
Unhappy Bearing/Wheel Hub Noise?
Hey everyone,
I have a 2000 GMC Jimmy 4x4, and around 20-30mph, under (extremely) light throttle, I get an intense whirring noise from the right rear tire. If I give it a little more gas, the volume lowers, but it's still there.
Around 35mph, it's constant. If I'm completely off the gas, I get the same sound just softer.
What's bad? My wheel bearing? Hub? Talked to dad, and he mentioned it could be a bearing but whether it was inner or outer bearing he couldn't say.
Like to consider myself Blazer savvy (brother and mom have one too) but I definitely need some help. It's driving me nuts.
Thanks you!
Old Apr 17, 2010 | 11:49 PM
It definitely sounds like it could be a wheel bearing. They are fairly cheap in terms of parts, but you do have to pull the rear diff cover to be able to get the c-clip out and remove the axle.
You may want to check the u-joints as well.
Old Apr 18, 2010 | 02:51 AM
GMJimmy's Avatar
Thanks for the quick response! I'm going to talk to my shop guy and see if he can swap a new one in. Part is around $30, any idea how much labor would be?
Old Apr 18, 2010 | 04:58 PM
Shouldn't take too long. Depends on how familiar the mechanic is with GM axles and if he has the proper tools to remove the old bearing from the axle tube.
samurai_24
Oct 2, 2009 12:39 PM
Maldo15d
Tires and Wheels
Jul 26, 2007 06:59 PM
bigrackhunter50
Apr 11, 2007 01:08 AM
Marcin
Nov 9, 2006 11:31 AM
Chavez96
Sep 20, 2006 04:04 PM
