IDLE ARMS
Old Jan 14, 2008 | 08:47 AM
bragdog's Avatar
bragdog is an unknown quantity at this point
Default IDLE ARMS
I was told by the place that put my tires on that they couldn't do an alignment because I needed new idle arms. Is there a way to tell if they are going bad?
Old Jan 14, 2008 | 09:43 AM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Default RE: IDLE ARMS
Grab ahold of it, and shake it.... if you can move it, it's bad.
Nother method, but, requires a friend. Turn the key to the run position, but, do NOT start the motor. Have a friend move the steering wheel back and forth, just to the point that it starts to influence the front tires. Look for the parts that move that DONT move the parts the are attached to.... (look for the slop) that will give you an idea of what parts need replacing.
Old Jan 14, 2008 | 10:01 AM
Another good synopsis of the troubleshooting steps Brian! I've said about the same thing in a few other, older threads.
Old Jan 14, 2008 | 10:41 AM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
Those things were so under-designed by GM that it's a good bet that if it's 11 years old, it's bad. Mine was toast at around 80K miles and I've always maintained good tires, balance, alignment, etc.The good news is that the replacement industry fixed the design and any decent name brand you buy will be a much more beefier part.
Old Jan 14, 2008 | 10:43 AM
By the way...I noticed you said idler armS. If they're trying to sell you two, you need to find a new shop. There's only one on the truck.
Old Jan 14, 2008 | 11:01 AM
bragdog's Avatar
That was just my stupidity. I meant idler arm.
Thank you so much for all of your tips.
Old Jan 14, 2008 | 01:10 PM
HeyYou's Avatar
I heard rumors that the idler arm from a half-ton truck would work as a replacement as well. Any truth to that? Or, is it simply the same peice??
002blazerdude
Lifting Tech
Oct 27, 2010 09:43 AM
magnum434
Sep 21, 2009 10:47 AM
Yooper
Jul 26, 2009 03:01 PM
alexbtango15
Suspension Tech
Jan 7, 2006 01:06 AM
Talusgirl
Oct 8, 2005 04:33 PM
