IDLE ARMS
Grab ahold of it, and shake it.... if you can move it, it's bad.
Nother method, but, requires a friend. Turn the key to the run position, but, do NOT start the motor. Have a friend move the steering wheel back and forth, just to the point that it starts to influence the front tires. Look for the parts that move that DONT move the parts the are attached to.... (look for the slop) that will give you an idea of what parts need replacing.
Those things were so under-designed by GM that it's a good bet that if it's 11 years old, it's bad. Mine was toast at around 80K miles and I've always maintained good tires, balance, alignment, etc.The good news is that the replacement industry fixed the design and any decent name brand you buy will be a much more beefier part.
Yooper
Jul 26, 2009 03:01 PM
