Idler arm
Old Jun 22, 2018 | 09:13 PM
Toolman1's Avatar
Toolman1 is on a distinguished road
Default Idler arm
I have a 2002 zr2 blazer. I've had to replace the idler arm couple of times since I've had it. Only had a year. Is there an upgrade or something I can do. I also want to lift it more to get bigger tires under it. Any suggestions would be appreciated.
Old Jun 27, 2018 | 06:34 PM
abig84's Avatar
I had the same issue with my 1990 silverado, seemed I was changing the cheap ones every 4 months. I bought a oversized moog one and it's been fine for the past 5-6 years. It's a bit bigger and a lot more expensive I think it was like $100 maybe they have something like that for the s10.
Old Jun 30, 2018 | 10:51 PM
If you want the ultimate upgrade, install an idler arm for a 1-ton truck using this bracket: https://www.outfitterdesign.com/1-to...m-bracket.html
I installed a Moog idler arm and so far it seems ok but I could see it failing if I were the type to go fast when off-roading.
orbitalcircle
Jun 14, 2015 02:48 PM
Forist72
Jul 16, 2014 12:21 PM
Jase1979
Nov 4, 2012 12:49 AM
dryden3
Dec 9, 2011 05:17 AM
frankjc
Suspension Tech
Sep 11, 2006 04:29 PM
