Installing front lowring springs
Old Jul 22, 2009 | 08:56 PM
3hondacrx's Avatar
3hondacrx is an unknown quantity at this point
Default Installing front lowring springs
I have recently installed a lowring kit on my 97 blazer and I didnt put the one inch spacers in cause I didnt think id need them. Well after drivin it for about two weeks ive decided that the front was way to low then the rear plus the ride sucked bad... So I decided to put those 1'' spacers in and now I cant get the spring back in and alligned. I seperated the lower ball joint and the tie rod and sway bar and it seems that its impossible for it to fit in right. Ive tried a spring compressor and no dice. I remember having the same issue before but now that im trying to ad the spacer theres just no room. Does anyone have any suggestions on how to get these in???
Old Jul 22, 2009 | 10:02 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
do you have the spacer on top of the spring? if so it could be getting caught up on something and if thats the case try useing tape to hold the spacer in place and try again. if it doesnt go easily youll just have to keep fighting it.
Old Jul 22, 2009 | 11:46 PM
3hondacrx's Avatar
Yeah the spcer is on top, I actually glued the dam thing on and faught with it for about two hours and then it started to rain real heavely so I stopped I thought about unbolting the the lower control arm from the frame I think thats how I did it before. I guess I can try that next time I get to round two!!!
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
greg3000
15
Feb 27, 2010 08:57 PM
dsrp
Jan 12, 2010 03:48 AM
Big E
Suspension Tech
Feb 12, 2009 08:25 PM
lt170chevelle
Lifting Tech
Sep 25, 2008 04:19 PM
