Leaf springs and Shocks
Old Mar 22, 2023 | 11:53 AM
  #41
moosehauler05'blaz's Avatar
moosehauler05'blaz is on a distinguished road
Originally Posted by Cimmerian
I tried searching the forums but either I'm getting old and blinder (likely) or just not using the search function correctly. Anyway,to get to my question :
I have the 2.5 in Rough Country lift on my 2000 LS 2dr 4x4 Blazer. I want to replace the leaf springs, spring bushings, and get four new shocks since I think the ones that came with my lift kit are shot.
I know having the lift kit in the mix complicates matters, so I don't know which brand/part numbers to get. I was looking at getting all Bilstein shocks but apparently I can't use their regular Blazer ones with the lift kit? Can you guys give me a hand with manufacturers and part numbers? I'm looking for heavy duty stuff since I live in a rural area and there are lots of trails and unpaved roads. Thanks!
EDIT :
I have confirmed that ZR2 OEM Bilstein shocks do work on regular 4x4 Blazers. Part numbers are :
The front shocks, 24-014120
The rear shocks, 24-018197
These are Bilstein B6 4600 shocks.
I can also confirm they work for a 2005 Blazer LS 2Door with a 2.5 inch rough country lift.........Note You will not want to fully extend your front keys to 2.5 inches In my case I had a hard time with a shop over the keys and alingment The results was the RC shocks ether blew Or could not handle the height And you would get a double dip of the shocks and a bottom out feel to it on the smallest of bumps in the road And looking the ZR2 is not 2.5inchs taller than the LS model it is 2 inches only And ya I would say you are off 1/2 inch before that shock travel is used And 1/2 inch before it returns It does have a effect ..And still better than the OEM RC shocks lol ....If you feel this ..Turn your keys a full turn each lower
musclemasterflex
Suspension Tech
Sep 20, 2011 09:23 AM
tri94bbc
May 6, 2011 10:22 PM
hnm3355
Jul 5, 2010 08:03 PM
Rowdus90
Nov 6, 2009 12:20 PM
MaNiAcUk
Oct 23, 2007 09:14 AM
