Left front wheel making metal on metal scrape during right turns
Old Feb 28, 2012 | 11:49 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Originally Posted by pettyfog
Let's try to maintain a little credibility here.. AC Delco doesnt have 'ownership' of every part they might sell. They ARE an aftermarketer like many others.
For example after reading some reviews here and elsewhere they arent on the top of my list for oil filters.
I dont especially believe they are going to sell superior parts to Moog/National, Timken or SKF.
BTW, CNBD.. if I have a part that only lasts me 8 mos and a year in succession, I'm gonna find a way of letting you guys know the brand.
AC Delco in my opinion used to be the best, but not anymore. I have had better luck with other brands.
These bearings are Carquest and they have different suppliers with the same warranty (1 year). In December when I brought a warranted bearing back they blamed it on the installer who might have overtightened the axle nut, but they replaced the bearing anyway. That I can believe since that is what happened with the last set of bearings before that when another mechanic said that the axle nut was near impossible to remove when he went to replace an axle seal. Next bearing failure will be out of warranty, so at that time I will order them online and cease buying parts from Carquest completely. Especially since their parts are so cheaply made that I can find cheaper parts online or even just down the road at NAPA or Advance Auto that work better and are cheaper.
Old Feb 29, 2012 | 07:50 PM
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
Default Bad alignment
I say it's a bad alignment that's causing the inside of your rim to rub against something. My guess is the rim's inside is rubbing against the stabilizer bar (specially if it's an R series not a C)
Old Feb 29, 2012 | 08:09 PM
coolasice's Avatar
coolasice will become famous soon enough
the first time i was working on my ball joints I managed to use the wrong bolt on my abs sensor wire hanger and when I turned sharp left it rubbed the inside of my passenger side wheel... shorter bolt went in and all was well
Brandon Koharchik
Oct 30, 2013 09:52 AM
old skool luvr
Shows & Clubs
14
Jul 24, 2010 10:16 PM
xxdatricandudexx
May 24, 2009 09:31 PM
Lockback
Aug 22, 2007 12:24 PM
rooster
Jun 7, 2007 08:40 AM
