Leveling out.
Old Dec 20, 2012 | 06:40 PM
armykyle1's Avatar
armykyle1 is on a distinguished road
Default Leveling out.
I guess this might be multiple issue situation.
My front end sits pretty and the rear seems to be sitting right, or maybe the rear is sagging? I looked at few other ZR-2's and it seems my front end is indeed higher.
Is there any way to tell if the previous owner cranked up the torsion bars on this thing?
I guess I'm wondering, should I head up to the alignment shop, throw some higher shackles on it or?
On pavement it's much more noticeable, for reference those are 31x10.5's
Old Dec 20, 2012 | 07:16 PM
El_Beautor's Avatar
Looks to me like you have the saggy aZZ problem with most of the Blazers. It looks more pronounced on the 2 doors because of the shorter wheel base.
You have a few options:
1. New leaf packs - expensive, but it solves the problem and gets you back to factory ride height.
2. Shackles - Cheap and addresses ride height, but doesn't really address the issue of saggy springs.
3. Add-a-leaf - adds lift to the leaf pack and stiffens the ride, but may exacerbate the problem of the main leaf sagging beyond the end of the add-a-leaf making a W shape over time. This is the problem mine have developed after 3 years with a Superlift long AAL.
4. The so called "Ba$tard pack - Taking the main leaf from another s-series leaf pack, and cutting the eyes off to add support to the entire lenght of the main leaf in your spring pack. WarthogDriver and a few others have done this with great success. This is probably the option I'm going to take in the spring.
Old Dec 20, 2012 | 08:00 PM
armykyle1's Avatar
I was leaning to doing the shackles. Eventually I'll put new leafs on it.
Old Dec 20, 2012 | 08:07 PM
armykyle1's Avatar
Also, I'll probably be adding helper backs to the rear since I'll be adding a bunch of weight.
480-560lbs in batteries alone.
Old Dec 20, 2012 | 08:17 PM
Dk1oldbill1054's Avatar
Dk1oldbill1054 is on a distinguished road
Thats alot of battiers
Old Dec 20, 2012 | 08:31 PM
armykyle1's Avatar
Yea lol, 6-7 D3100's
It's a tad overkill really, but I'll be running two 5k amps to start with 3-4 4ch amps to run all the highs. Might eventually step up to 7k amps.
rickmfromnh
Aug 15, 2011 07:30 PM
NYBLAZER
May 10, 2010 01:22 AM
akcalvin
Lifting Tech
14
Mar 19, 2009 10:08 PM
Unlimitedsp
Feb 12, 2008 01:52 AM
Rp9110
Jan 5, 2008 11:27 PM
