??lockers??
Old Feb 9, 2009 | 06:46 AM
Default RE: ??lockers??
ORIGINAL: butters
http://nh.craigslist.org/pts/1022061234.html
would this help?
That one is for the 8.5" rear diff. It will not work with the 7.625" diff that your truck has.
Old Feb 9, 2009 | 08:04 AM
WolfPack's Avatar
Even if you swap in a ZR2 rear end and end up needing to replace the G80...it should be noted that there is a difference between the 8.5 and 8.6 axles. It looks like GM switched in 1999, so some of them have 8.5s and some have 8.6s, but 2000+ they all have 8.6. So depending on the year axle you get, you might need some extra parts to get it to work (assuming its designed for an 8.5. If its an 8.6, it wont work in the 8.5!)
Check out this thread on ZR2usa showing the differences: clickkk
Old Feb 23, 2009 | 07:36 PM
96chevblazer's Avatar
but if you welded your spiders together wouldnt that be the cheapest and it would also do the same as a full time locker right??
Old Feb 23, 2009 | 09:03 PM
WolfPack's Avatar
It could work the same, but its really not the safest option.
Old Feb 23, 2009 | 09:10 PM
ORIGINAL: 96chevblazer
By saying "locker", that would imply that it has the ability to unlock. By welding up your gears, you are effectively making the rear axle solid like a spool would do, just a lot more weak...
Old Feb 23, 2009 | 11:23 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
well i would like them too
Old Feb 23, 2009 | 11:32 PM
WolfPack's Avatar
GP?
Bravado
Sep 11, 2009 11:23 AM
Cavalier z24
Jun 20, 2009 08:22 AM
lil_blazin
May 9, 2009 02:53 PM
sorrymissfofo
Oct 3, 2007 07:59 PM
zero psi
Feb 20, 2007 08:56 PM
