Loose stearing
Loose stearing
I was wondering, i have a '94 blazer 2 door. My brother was in it one day and said that my stering was loose. How do i fix this?
RE: Loose stearing
adjust your steering box there should be a adjustment screw on it to adjust it i believe to tighten it up
RE: Loose stearing
If that is in fact the problem. And it isn't as simple as adjusting a screw to tighten up the factory steering box. Too tight and you'll be looking at a new box in short order.
With many, many vehicles, it is a worn or failed component in the steering that is the cause. We have had a few threads on the subject of what to check in the steering. These include tierod ends, the idler arm, and the pitman arm.
RE: Loose stearing
and the adjusting anthing on the steeing box is the extreme last thing you want to do.
cameron skaggs
10-13-2014 12:51 PM
