loose steering
AARRGGHH!! My 2000 ZR2 wanders somewhat when driving down the highway and the same when coming out of turns, especially sweeping turns at fairly high speeds. It's uncomfortable, potentially dangerous when cars are next to me.
I have: replaced ball joints, (aligned front), steering gear box, mid steering shaft, gotten new tires (needed 'em anyway). Got frustrated, took it to a Chev dealer where they replaced the L/F inner tie rod and aligned, plus replaced a large gear in steering hub (ASM?).
The new result is that it feels as if I have ultra power steering; the wandering when going straight on the freeway is new; in a sweeping turn I can now hold it in place, but still have play when coming out of the turn and try to get into the new, straight path.
What the !!&$@!*%#@!! is going on? Any ideas out there?
Thanx, HighAlt
Thanx, HighAlt
rag joint on a blazer i have a 98 lt 4x4 and i have a little loose steering. got it check tie rods good new ball joints on driverside u/l. new wheel bearing on passenger. but my steering feels loose not bad but loose. so i jacked my truck up on the front end and moved my wheels side to side and my wheels steering shaft and steering wheel moves about 1-4 of an inch. someone told me my gearbox is going bad or just needs adjusted. how to adjust it????????
litterbug
Oct 19, 2011 07:50 AM
ussexplorer
Apr 11, 2010 06:53 PM
christine foxx
Oct 14, 2009 01:45 PM
