loose steering
Old Feb 3, 2014 | 02:06 PM
01xtreme_chevy's Avatar
01xtreme_chevy is on a distinguished road
Default loose steering
Steering driving me crazy. I have very loose steering probably about 2"-3" of freeplay before you are actually turning. I have replaced the idler arm and the center/drag link. New bearings in front. Still loose steering. The pitman arm is factory and the ball joints and tie rods are all factory. You can grab the tie rods and easily twist them back and forth with ease. The ball joints you can hear crack and clang on the slightest bump in the road. I do grease them with every tire rotation.
Could the ball joints, tie tods (inner and outer) and the pitman arm cause slack in the steering? Is there a way to diagnose the issue before I start replacing?
Old Feb 3, 2014 | 02:49 PM
Diaita's Avatar
That much slop, I'd suspect wear in the steering gear as well.
Old Feb 3, 2014 | 02:55 PM
I'm guessing you're talking about the steering box itself?
Old Feb 3, 2014 | 04:02 PM
BlazinAmazin's Avatar
BlazinAmazin is on a distinguished road
I just replaced my steering box for the same reasons. I got a low mileage used one, and it cured it! I had about 2-3" of play myself
Old Feb 3, 2014 | 04:04 PM
Diaita's Avatar
Yes, steering gear=steering box.
Old Feb 7, 2014 | 02:16 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Check the steering column, as well. The u-joints in those will wear out over time. I don't think it would account for ALL of the slop you're experiencing, but possibly some. Otherwise, gotta concur with what was already said.
litterbug
Oct 19, 2011 07:50 AM
ussexplorer
Apr 11, 2010 06:53 PM
injville
Dec 14, 2009 12:10 AM
christine foxx
Oct 14, 2009 01:45 PM
Cuchulain
Jun 17, 2008 05:24 PM
