Max Tire Size Safe for Stock Axles
Old Aug 23, 2012 | 11:35 PM
LunchBox's Avatar
LunchBox is an unknown quantity at this point
Default Max Tire Size Safe for Stock Axles
Hey...I'm researching a number of different lift and tire options...and one thing hanging me up is the max tire size that is reasonably safe for stock axles on a 2nd gen Blazer 4x4. I thought I read somewhere that 33's was the absolute max...and only for very occasional/light wheelin'.
Forget about the lift itself...that's another issue. All I'm concerned about is if stock front and rear axles will become damaged from mainly on road use with 33's. I think I can run 33's without a regear...but I don't want to start snapping axle shafts driving to work.
I tried searching a number of things bith here, and offsite...can't seem to find it.
Thanks
Old Aug 24, 2012 | 08:51 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
i wouldnt go bigger than a 32 on a stock axle, ul notice a huge lag of power with anything bigger. i ran 31s on my stock gears/axles for a cpl years with a 3" body lift, home made shackle and zr2 keyways, but im runnin a 4.3L. i noticed a big difference in mpgs, and power wheelin. it did alrite, but i def could use a regear. and with 33s, ul put a huge strain on ur cv axles. they are weak to begin with and when u put that big a tire on them they become toothpicks that are ez to break. if ur gonn lift it enough to wanna run 33s and not wanna worry about snapping axles look into a lil straight axle lift. same price as a ifs lift but stronger and more potential. plus, if u find a good set of axles ul have a regear too. a good set of jeep axles will give u what u want for lift and ul even be running 4:10 after. just a thought.
Old Aug 24, 2012 | 10:03 AM
Jamaroon's Avatar
I've never broken a CV on 33's with fairly hard wheeling. Yes, the rear ends are different between mine and yours, but front CV's are same strength.
You'd be fine on 33's for mainly street use.
Here's a link with my buddy's Blazer on 33's
https://blazerforum.com/forum/tires-...er-pics-71189/
Old Aug 24, 2012 | 12:56 PM
LunchBox's Avatar
Your opinion on stock gears? Also...I have a 5sp Blazer...I suspect my 210k mile clutch will finally crap the bed.
Old Aug 24, 2012 | 01:56 PM
Jamaroon's Avatar
3.42's? That's what he has, he says they're fine for street use. For off-road, they are somewhat hindering. He also has a 5 spd, which I think is why he is ok with stock gears, I wouldn't want to run 33's with an auto and 3.42s
Old Aug 24, 2012 | 01:57 PM
abig84's Avatar
some people can somehow make them last. me, i ran 33 12.50s on a stock s10 and broke a cv joint every time i turned the wheel halfway, no matter how much i babied it they just kept snapping left and right.... literally.
that was on a first gen though, but i think its all the same stuff.
Old Aug 24, 2012 | 09:23 PM
LunchBox's Avatar
I'll check my ratio tomorrow...or maybe later tonight after a few more wheeeskies. I've had a couple mechanics at various places tell me in the past that my Blazer has a "different" stock config than the normal ones they see. Dunno what that really means, if anything.
ng2279
Feb 11, 2015 06:31 AM
bhsdrillr
Oct 26, 2014 10:49 AM
LucasMI
Tires and Wheels
Dec 22, 2010 02:20 PM
KarlofZR2
Tires and Wheels
Jun 28, 2010 07:53 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
