Miserable UJoints Seriosly.. Nylon retainers?
Old Sep 3, 2011 | 12:40 AM
musclemasterflex's Avatar
musclemasterflex is on a distinguished road
Default Miserable UJoints Seriosly.. Nylon retainers?
So after beating my driveshaft for an hour.. did some more searching and found that my stock driveline had a internal nylon retainer holding the ujoint on.. This video was way helpful
Replacing a U-joint in a 1999 Chevy S-10 4x4 - YouTube
Who knew, you would have to melt the clip out to remove the ujoint.
Old Sep 3, 2011 | 04:53 AM
chris015's Avatar
Yep,best ever! (not really)
Fun part is when your heating it with a propane torch,you will hear a loud pop,which is the nylon blowing..fun.
Old Aug 12, 2012 | 03:25 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
This is exactly what I was looking for. What would happen if you didn't put the shaft on the exact way you took it off, you forgot to make marks. Would you have balance issues and How do you know it's on correctly if you didn't make marks? Does a shop have to balance check it or something?
Old Aug 12, 2012 | 03:53 PM
xgiovannix12's Avatar
It only goes on 1 way I think. Im not 100 % sure.
Old Aug 12, 2012 | 04:05 PM
Because everything I have read say's to mark the shaft so you put it back on the same. Also I was just looking and are the front drive shaft u-joints press out's? They don't appear to be nylon. How do you get them off, do you remove the cap over them somehow?
Old Aug 12, 2012 | 05:01 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
I marked mine but forgot about it after melting the nylon retainers out, and put it on the way it wasn't marked haha. And I have done several u-joints at work and never marked them, all turned out ok.
Old Aug 12, 2012 | 06:12 PM
the mark is so you don't go crazy putting it back on.
I never marked mine either. I always tend to put the shaft back in right away too.
billyfromhill
Sep 27, 2014 09:57 PM
spittybays
Oct 19, 2012 03:34 PM
volcer
Mar 15, 2012 04:51 PM
urbex
Nov 27, 2009 06:17 PM
