My 2003 chevy s10 will only drive I'm 4wd
Old Nov 13, 2023 | 04:58 PM
Jojo1214q's Avatar
Jojo1214q is on a distinguished road
Default My 2003 chevy s10 will only drive I'm 4wd
My s10 was making a roaring noise an when I was going to work one morning it made a awful clunking or grinding noise I pulled over an cut it off when I cut it back on put it into gear pushed the gas wouldn't go anywhere but when I finally put it in 4wd drives fine but still makes a noise when I push tye gas when I stop pushing the gas it stops also noticed before this happened there was grease under towards the rear end an I don't wanna replace the whole rear end or front if I don't have to any suggestions please
Old Nov 13, 2023 | 07:44 PM
Sounds like you need to pull the rear differential cover and assess the damage inside. It sounds like there likely is damage to the ring and/or pinion gear.
bensaintonge
Nov 11, 2013 09:17 AM
01blazer4.3p
Dec 4, 2011 10:02 PM
ant22
14
Apr 7, 2006 05:21 PM
